S30A Removing the front/drive wheels..
Is there special way to remove the front wheels on the S30A? There are two set of lugs nuts. An outer ring and an inner ring. I'm assuming the outer ring of lugs bolts the tire/drum to the axle and the inter ring is the axle. I've removed the outer ring nuts but can't get the wheel off. Is it just stubborn or am I missing a step?
  • Posted 10 Sep 2019 04:55
  • By kevin_kurland
  • joined 16 Aug'19 - 19 messages
  • New Hampshire, United States
Got it Thanks!
  • Posted 13 Sep 2019 05:09
  • By kevin_kurland
Swoop is correct. There should be wedge rings under the lug bolts. You need to smack the wheel with a hammer this should loosen the wedge rings. Use a screw driver to remove the rings.
  • Posted 10 Sep 2019 23:22
  • By BREWSKI
BREWSKI
you might want to check for an alignment bolt, might be counter sunk, if you dont see anything like that then...
Other wise you probably want to take a small sledge and hit the rim a couple times to break it loose.
  • Posted 10 Sep 2019 16:06
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
Nagano NUL120-6
Unicarriers FHGE35T5S
Yale Lift Truck Technologies
edition #1280 - 7 May 2026
In this week’s Forkliftaction News , it’s financial reporting season with Hyster-Yale, KION Group and Konecranes all reporting revenue falls for Q1, yet maintaining their forecasts for moderate growth and stable sales volumes for the year... Continue reading
