Crown RR3000:
RR3560-45 LIFTS OUT OF SEQUENCE
THE CHAINS AND CABLES ARE GOING SLACK WHEN THE SECOND STAGE SHOULD START TO LIFT. I NOTICED THE THIRD IS UP ABOUT 2-3" -WHAT WOULD CAUSE THIS TO LIFT OUT OF SEQUENCE? -TROY
  • Posted 30 Jan 2011 06:29
  • Discussion started by troy_m
Thanks -will check that tomorrow
  • Posted 4 Feb 2011 11:14
  • Reply by troy_m
The chains should have some tension on them when the mast is fully collapsed and the channels are setting on their poly stops. I once had a mast on this model truck with a channel up a few inches and it turned out to be the bolt that holds the mast to the truck at the bottom of the mast. It was sticking out and keeping the mast channels up a bit.
  • Posted 2 Feb 2011 10:50
  • Reply by Liftdoctor
  • Indiana, United States
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
