ROCLA error code AL98
Good day all, I have an error code AL98 on a Rocla Pallet truck (model SW16S1500E, with a Zapi controller) when I start it up for approx. 1 minute, after that time the error disappear and it's possible to drive and lift with it. According to the only information I have it's input error 2, but I don't really know what it means. Is there someone there that has more information of it and can help me?
Kind regards
marcb
  • Posted 19 Apr 2012 01:21
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
Hi,
I`m looking for Rocla service manuals too
Does anyone help... We have info. to share
Thanks in advance
Folk
  • Posted 13 Mar 2013 01:55
  • By for_y
  • joined 21 Apr'10 - 63 messages
  • Sao Paulo, Brazil
thetarget7@ymail.com
Hi !
I need help.
me very need workshop manual for Rocla F14, TTI15DS3300, ТW 20аср, HX 16S, SW 16as.
there is something for them?
I have a lot of manuals, we can share!
Thanks for the help!
regards Vladimir
  • Posted 15 Nov 2012 08:25
  • By vova_s
  • joined 11 May'10 - 39 messages
  • S-W, Russian Federation
In case you have sw16 with Zapi Combi controller alarm description is:
"Mdi hour meter and chopper hour meter ar different (only on MDI)"
This can come up if you replace the controller and you do not disable parameter "load hm from MDI". If you replace the controller and you can't change the parameter, just wait for few minutes and truck will work normally.
  • Posted 27 Jun 2012 06:20
  • By simo_s
  • joined 21 Jun'12 - 7 messages
  • helsinki, Finland
Hello all,
Thanks for your replies, the problem was inside the controller. I had it repaired and all works well now.
Kind regards
marcb
  • Posted 14 May 2012 17:08
  • By marc_b
  • ANTWERP, Belgium
Marc b i was found something interesting for you.AL 98 that you have with MDI hour meter means automatic updates of the hours of the hour meter with the hours in the combi and solution for this says wait for one minute.I was have this when i was do clear eprom with diagnostic just on the first start up but not after that.Are you change MDI?Is it your connection on MDI ok?This is not block error but it is not normal for MDI to update hours every time when truck start.
  • Posted 20 Apr 2012 05:44
  • By nemanja_k
  • serbia, Serbia
hey gc; thanks for your reply.
we already controlled all the wiring and connections, the strange thing is that if we wait (after switching the contact on) for approx. 1 minute the error disappear and it is possible to drive. Another thing is that I found out that error AL98 could mean 2 errors.
- input error 2
- cleaning MDI HM (battery discharge indicator)
Do you have the same info about the second error?
Kind regards
marcb
  • Posted 19 Apr 2012 19:46
  • By marc_b
  • ANTWERP, Belgium
Hi Marc,
INPUT ERROR #2 (AL98) Failure to detect the rapid inversion input on the controller.
Possible causes:
a) input from the rapid inversion microswitch is missing
Solutions:
a) check connection of the serial cable, if the fault persists
renew the controller
Check the drive switch in the drivers hand.
  • Posted 19 Apr 2012 17:38
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Sorry i dont work rocla like model but i was work simular models with this electronic unit.They have card in drivers hands and that card have communication with main electronic unit.When is that wrong shows this error.I think is the same in your case pleas look and tell me if i am wrong and i will try to find something for you for data of model.
  • Posted 19 Apr 2012 07:17
  • By nemanja_k
  • serbia, Serbia
hello nemanja, thanks for your reply. Do you have by any change an elektric diagram, or do have an idee where this tiller card is located?
kind regards
marcb
  • Posted 19 Apr 2012 04:27
  • By marc_b
  • ANTWERP, Belgium
Marc b al 98 is input error 2 and that means that wiring from electronic unit to the tiler card is bed.Check cable from controller to the card, probably bed contact or bed wire.
  • Posted 19 Apr 2012 04:08
  • By nemanja_k
  • serbia, Serbia
Libiao Robotics
Crown RD572513TT6860R
Factory Cat MICROMAG20D
Deborah Baker Deborah Baker
