riding speed lpe 200
a bt lpe truck suddenly stopped riding; no error code
need to says that some weeks before the footboard had been damaged. Disconnected the hip support position sensor and the foortboard position sensor and it will only travel at walking
speed. Bridged the sensors on all possible ways.
With the sensors connected it wont move!
should the probleem be the curtis box?
regards
  • Posted 28 Oct 2012 04:31
  • By stefaan_n
  • joined 28 Oct'12 - 1 message
  • nt, Belgium
How old is the truck, around late 2009 / early 2010 build the sensor spec changed.
Has it got the old mechanical type sensors OR the newer proximity type sensors?
There was an issue with the proximity sensors fitted on the early build of trucks at the changeover point where the platforms wasnt shimmed correctly at the factory, the arm needs to be within 6.5mm of the sensor area to activate the sensor.
The old type mechanical switches the ends with the sensor wheel can get smashed off.
The is 1 switch on the safety arms.
There are 2 switches on the platform.
1 switch senses when the platform is folded UP for walk along mode.
The 2nd switch senses when there is a person standing on the platform.
If any of the platfrom switches fail the truck wont drive as the built in safety logic wont allow it to.
The new proximity switches also suffer from people breaking the locking tab of the electrical connector plugs so the plug can then come loose.
Disconnect both platform sensors, fold the safety arms DOWN, walk the truck & lift the arms UP, truck should STOP - this will proove the arm switch is working correctly.
  • Posted 28 Oct 2012 20:53
  • By Forkingabout
  • england, United Kingdom
sounds like a bad sensor or damaged wiring?
or maybe just incorrect sequencing when activating these sensors (switches)?
the hip support sensor just sounds like an operator presence switch that activates the system when closed.
the footboard sensor could be a high speed trigger switch and should only be activated when the truck is in motion. If you activate it before you start driving it will do nothing, you will need to open the switch and then close it again while moving.
i would check the sensor inputs at the card and see if your getting any signal from the sensors, if not then check the wiring, if you are then sure, the curtis unit may be damaged.
i'm just making educated guesses here i do not know this truck so....
try this and see if that helps
  • Posted 28 Oct 2012 11:17
Sue Tomic Sue Tomic
