By the sounds of it. Your timing oil pump is out or you dissy rotor/cap is worn.
Hi Chris, this is Rolf from South Africa. I have the same problem with my Linde Forklift 350H09111716. The engine starts beautifully but revvs up immediatly to full power.
You had the same problem with your machine. How did you solve it? what was the reason? Linde in Cape Town is closing down and I cant get any professional help from them.
Your help is much (!) appreciated
With kind regards
Rolf
Yes all set up correctly - unfortunately it is not laptop compatible - was Linde engineer for 18 years and never come across this before.
Did you calibrate the truck after changing the pot?? Any error codes showing?? To be honest without a laptop plugged in your going to struggle
