Replacing hoses - time?
How big a job to change out the two long paired hose assemblies (side-shift) running from the mast to the retractor reel? Working blind - not a brand I've seen before & no service manual for procedure. Any pointers much appreciated - thx
  • Posted 27 Apr 2019 22:38
  • Modified 29 Apr 2019 00:05 by poster
  • By Nleonard
  • joined 27 Apr'19 - 1 message
It's a bit of a sod of a job but shouldn't take much more than a 3 or 4 hours at the most the first time you do them. I normally do them in a couple of hours. You will,have to take the hose real out and before you do make sure you lock it in position so you don't loose spring tension
  • Posted 7 Jun 2019 02:58
  • By lifter01
  • joined 4 Jul'09 - 465 messages
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
