Replaced water pump, truck will not start.
I have a Doosan G25E, that I had to replace the water pump on, and now it will not start. There is no spark coming out of the coil.(Checked w/ inline spark tester.) Had to remove the timing covers to get the water pump off, as it covers the water pump bolts. Also I had to remove the crankshaft pulley to get the bottom cover off. I am getting less than 10volts coming out of the coil harness connector and relay. The battery is good and fulley charged. I did not touch the timing belts and the crankshaft pulley only goes on one way( as it has a dow pin.) All of the grounds have checked out fine so far. Need help, thanks.
  • Posted 2 Apr 2019 15:36
  • By jbhunt
  • joined 28 Mar'19 - 1 message
  • Kentucky, United States
Joshua B Hunt
Hi dear friend how are you.
I have the same problem.
What do you do for this problem?
Do you solve it?
  • Posted 25 Jun 2024 05:43
  • By Afshin
  • joined 29 Aug'23 - 34 messages
  • Iran, Islamic Republic Of
edition #1264 - 15 January 2026
In this week’s Forkliftaction News , we look at the top five robotics trends forecast for 2026 from the International Federation of Robotics, and it’s an eye-opening read with the potential for robotics, AI and automation to work together to change our sector in fundamental ways... Continue reading
Australia was the first nation to successfully convert its paper-based currency to polymer banknotes, a technology developed in the same country. The first polymer banknote was a commemorative $10 note issued in 1988 to mark the Bicentenary. The first polymer banknotes were also the first to feature a transparent "window" as a security feature.
