hi
when turn on swich the error code f6 appear and line contactor work about one moment and all of system doesnt work.i changed transistor t1p with t1d and error changed to f2
please help me
THKS
Sorry there has been discusion that i could get in trouble for helping. I will say this, both these codes will cause the line contactor to open, causing no operation of any function.
thanks for your attention
i tested 3 transistor and pump transistor isnt correct but drive transistors are correct and now my question is why drive doesnt work while error is for pump transistor
and at label of transistor write a number and i didnt find any information about it in fuji electronic site
thanks
I think you answered your own question, it appears pump transistor is shorted and when you switch to drive side it gave you a drive transistor short code(f2). Check you transistor between emitter collector and base for shorts.
