Release Washer Button
I have a forklift that is showing sometimes RELEASE WASHER BUTTON on the LCD screen but this forklift do not have this function.
This message do not let the forklift start.
Any idea what is causing this issue?
  • Posted 25 Feb 2020 07:47
  • By Oscar_Bastos
  • joined 19 Feb'20 - 7 messages
Oscar B
Yes replaced dash and all seems well now. Thanks for the help.
  • Posted 22 Dec 2024 09:01
  • By J_Meppelink
  • joined 17 Dec'24 - 4 messages
  • Michigan, United States
It seems to be a fairly common issue on the ft range if the truck is left outside in the rain, water gets on the switches and shorts them, a work around that usually works is turn on the truck press the dash up button (bottom right) for 10 to 30 seconds until you get a release up button warning release it then your truck should start. Ultimately you need a new dash
  • Posted 21 Dec 2024 18:15
  • By lifter01
  • joined 4 Jul'09 - 463 messages
I suspect the truck is going to just need a software update. I'm a Hyster/Yale Service Manager, but I've not heard of this issue before. I will update this thread if I can find more information on it.
JK
  • Posted 19 Dec 2024 02:28
  • By Jeff_Krueger
  • Colorado, United States
It seems to only happen after lifttruck sits for awhile. But when you go to start it , it won't crank over. And when you release the key to the wrong position. It says release washer button. Then if you wait while leaving the key on the LCD screen switches to temp and then you can crank it over and start it. The waiting time varies as little as 20 seconds or as long as a couple minutes. but it will not crank as long as it says release washer button. I have looked for loose connections, wiggled wires, and tapped on ECM. It seems to have a mind of its own.
  • Posted 19 Dec 2024 01:47
  • By J_Meppelink
I have gone through the manufactures diagnostics pages and the service alerts. I'm not see anything regarding that message. Do you have any additional info?
  • Posted 19 Dec 2024 00:12
  • By Jeff_Krueger
Serial number is C809V02451D
  • Posted 18 Dec 2024 09:39
  • By J_Meppelink
Do you have the serial number for this unit?
  • Posted 18 Dec 2024 09:33
  • By Jeff_Krueger
Did you ever get an answer to your question on this forklift. I have a Yale with the exact same problem. Hopping you can help
  • Posted 17 Dec 2024 05:47
  • By J_Meppelink
Maxlion R2D35
Manitou M50-4
Maxlion R2D35
Manitou M50-4
Maxlion R2D35
Manitou M50-4
