Linde (& Baker) H25D-03:
Release Drive to allow to push
Hi Can any one tell me how to release the drive, We need to push the forklift.
Full details Linde H25D-03 Serial No H2X351M02329/2001
Thanks Nigel
  • Posted 30 Nov 2011 23:55
  • Discussion started by nigel_p
  • Worcestershire, United Kingdom
truck can be jacked up before you start.when its time to use the truck again. screw allen bolt in tight, screw octagon stud in tight and tighten jam nut. if stud is not tight, unit will not stop when driving, it will coast
  • Posted 22 May 2015 11:05
  • Reply by edward_m
on the brake valve their is an allen head bolt, loosen it so that you have about 2 threads holding it. then look down at the air cleaner toward the hydrostat. straight down from the cap of the air filter. their is an octagon stud with a jam nut.jam nut takes a 19 mm socket. I loosen the jam nut and the stud comes with it.screw the nut down till only 2 threads show. screw it back in an tighten. this is to help release the brake.pump brake pedal with your hand untill pedal is tight. jack up truck on 1 side and you should be able to push the drive wheel with your hand
  • Posted 22 May 2015 10:59
  • Reply by edward_m
Crown SX3030TT4250
Toyota 02-8FD30
Johnston, IA, United States
St. Louis, MO, United States
Jefferson, WI, United States
Enforcer FLBAXT25
JLG 600AJ
JLG 600AJ 2012
Flesherton, Ontario, Canada
