Recognition of damaged component in controller model: 51617861
Good evening, and thank you for your attention. We currently have a forklift with the active code 3501.1, and according to the description in the message/error table, the AC-3 Power Control interface card needs to be replaced.
We have removed and inspected the controller's PCBs, so far finding two damaged components: two integrated circuits and a blown 10-amp fuse (position 7F3).
We have identified one of the integrated circuits as the ADUM1286 (Dual-Channel Digital Isolator). The other one is unrecognizable due to being burned; we can only determine that it is from the brand LT (Linear Technology). Both are connected through pins 6 and 7 of each IC, respectively.
We were informed that the issue originated after external lights were connected to the controller's output (+UB) in order to have control over the lighting after turning the forklift's ignition key.
Since I cannot share an image or indicate the position of the integrated circuit because it is not labeled on the PCB, it is located on the second board near the +UB and +UB(B) input.
I appreciate the help provided in advance.
  • Posted 13 Mar 2025 10:26
  • By Fredy_Patino
  • joined 13 Mar'25 - 1 message
  • Peru
I read your post and I am working in a similar unit like the one you have. According to your description the circuit you are looking for is the LT4356CMS-3#PBF , PART MARKING ; LTFFK 10-Lead Plastic MSOP.
  • Posted 24 Mar 2026 21:10
  • By Anuar_pacheco
  • joined 24 Mar'26 - 1 message
  • Dublin, Ireland
Merhaba Parça numarasindan kontrol ettim bu elektronikler üzerine fazla akim çeken parçalar baglandiginda maalesef sorun çikartiyor. Bu nedenle kontaktör çikisindan akim almanizi tavsiye ederim.
Plase use English
Littoral Translation
Hello, I checked the part number, unfortunately these electronics cause problems when parts that draw too much current are connected to them. For this reason, I recommend that you get current from the contactor output.
  • Posted 21 Mar 2025 10:49
  • By brahim_ULUS
  • joined 21 Mar'25 - 2 messages
  • Turkey
Ulus Istif Makineleri ltd.sti.
US forklift tariffs now 15% Washington, DC, United States
edition #1285 - 11 June 2026
UN Forklift FB25N1LZ1
Morooka MFD20
