Really need help Fault Code 524230-3
My fork lift dont want to start and show this Fault Code 524230-3 i really need help to fix it
  • Posted 27 Oct 2016 10:49
  • By jesus_v
  • joined 26 Oct'16 - 2 messages
  • Not Applicable, Mexico
DTC 524230-3 - Rear Work Lights Relay (RL7) Driver Output OORH.
A. SAFETY SWITCH (IF EQUIPPED) IS DISCONNECTED
B. SHORT ON RELAY DRIVER OUTPUT TO UNSWITCHED BATTERY (SEE WARNING BEFORE CONTINUING)
C. SHORT ON RELAY DRIVER OUTPUT TO SWITCHED BATTERY.
D. SHORT ON RELAY DRIVER OUTPUT TO ANOTHER OPERATED DEVICE
E. CONTROLLER DRIVER OUTPUT TO RELAY COIL OPEN CIRCUIT
F. RELAY COIL OR GROUND CONNECTION OPEN CIRCUIT
G. FUNCTIONAL FAILURE IN CONTROLLER
  • Posted 27 Oct 2016 23:21
  • By BREWSKI
Yeah you need your local dealer to come and fix it.
There is a software upgrade you need.
  • Posted 27 Oct 2016 20:43
  • By stam
