RC5500 crown
Code 217,740,705
  • Posted 23 Dec 2015 02:18
  • Discussion started by yarisabel_l
  • Puerto Rico, Puerto Rico
Hi,
..is there more things to consider about 303 beyond what I have written in this post?
Kind regards,
Luis
  • Posted 28 Jul 2021 11:30
  • Reply by luis_v
  • Mexico
lvelasco@insercomm.com
Thanks, I think the problem might be the batt connector on the lift. I repaired the connector coming off the batt as it had bare wire exposed and was arcing and getting hot enough to melt the connector body slightly. Could have caused damage on the other side.
  • Posted 30 Jun 2016 08:05
  • Reply by randy_t
  • Washington, United States
I have never had to replace one on an RC5000 series. For me most Crown controllers have been pretty reliable. The only ones I have had multi issues with are SP steer controllers and PE SEVCON's
If your voltage is good maybe swap it with another truck before ordering one (If that is an available option). I would double check battery & water level if voltages are low. Check for bleed off to the chassis too...
  • Posted 30 Jun 2016 06:12
  • Reply by chevotaman
It's all just nuts n' bolts.
Is it common for the Access 3 module to go out, or Access 1?
  • Posted 30 Jun 2016 05:52
  • Reply by randy_t
I have the manual, thanks.
  • Posted 30 Jun 2016 04:47
  • Reply by randy_t
309 is access 3 cap not charging after power up...
Check voltage at access 3 B+ and B- with key on (powered up and both pedals depressed)
If 35-38VDC R&R access 3
If less than 35VDC refer to code 303 procedures. If you get to this point you need the manual. full page of T-shooting steps.
Check your battery condition!
Good Luck
  • Posted 30 Jun 2016 02:55
  • Modified 30 Jun 2016 02:59 by poster
Any tips on code 309?
  • Posted 30 Jun 2016 01:54
  • Reply by randy_t
Thank u so much
  • Posted 23 Dec 2015 07:30
  • Reply by yarisabel_l
217: Output driver for travel alarm short
705: Coil SVA1A open circuit
740: Accessory pot above or below calibrated range
  • Posted 23 Dec 2015 07:29
edition #1235 - 19 June 2025
Hitachi HX99B
TCM FD115-3
Harrisburg, SD, United States
Wentzville, MO, United States
Ottumwa, IA, United States
