Raymond RAS25 RAS 10-03657
I'm getting code E112, I REMOVED VEHICLE MGR. AND CLEANED, WORKED GOOD FOR A FEW DAYS NOW SHUTS DOWN AGAIN. ALSO LIFT CAME INTO SHOP LOW VOLTAGE. BATTERY TESTED BAD. INSTALLED 4 NEW GEL CELL BATTERIES. THE CHARGER THE CUSTOMER HAS FOR THIS LIFT IS MADE FOR WET CELL BATTERIES. WILL THIS CREATE A PROBLEM, WILL IT CHARGE TOO MANY AMPS? WILL CREATE OTHER ISSUES? PLEASE ADVISE. LIFT PERIODICALLY DRIVES THEN SHUTS DOWN.
  • Posted 31 May 2014 03:47
  • By fisherofman
  • joined 31 May'14 - 1 message
any help please i have a ras 25 raymond stacker the lift will not work it travels well , i did notice that the control handle has no resistance like the switch s is not working i did check the motor and i did remove the control handle and also went as far as removing a second truck handle off a known good handle and still not working i do not have a book and would like to know if there is PDFs i can get any help is greatly appreciated
  • Posted 18 Sep 2014 11:43
  • By justme
  • joined 23 Jan'08 - 19 messages
The gel cells are usually sold as a unit, charger and batteries. It is a different charger. Best to get proper unit first
  • Posted 5 Jun 2014 13:23
  • By EasiTek
