Raymond OPC 30TT Code 9F
Trying to bring an old unit back to life and have encountered a Code 9F. Unit has worked well for us in the past.
It has been out of service for 2 years. We charged the battery with a golf cart charger after checking water levels (our good charger is 100Ft away and haven't figured out a way to move this truck).
Got it to 23.2V. That should be good enough to start, right?
Power on goes into self test and then gives me a Code 9F. Anyone know what this is before I call a service tech? I'm Stuck.
Thanks all!
Scott
  • Posted 10 Apr 2018 01:06
  • Discussion started by Shughey7
  • Virginia, United States
23.2 is very low. Not sure if this is causing your code or not. What is the voltage when you turn on the truck?
  • Posted 10 Apr 2018 01:17
  • Reply by BREWSKI
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
