raymond EASI reach code 42
Can anyone tell me what is code 42?
No more up/down when it shows.
What need to be fixed?
  • Posted 11 Mar 2009 07:56
  • Discussion started by hellokitty
I have the same problem.. only with unit off contactor is open completely. Key the unit on and the tips close instantly. When the unit doesnt fail they dont close until i step on deadman. So basically im getting voltage to the contactor when i shouldnt. No visible shorts in wiring or harness. Im thinking its a vm issue.. any thoughts anyone?
  • Posted 30 Mar 2017 06:10
  • Reply by buddy84
Set the BSOC setting to lower if using older battery and also increase the CUTOFF to higher.
Check the basics first. Are you running your battery on low volts???? Is the battery in good shape or old and worn out?????. Stuck contacts are usually caused by low battery amps. I would disassemble contact Assembly, check condition of tips. replace if worn or damaged. Check condition of brush and armature on hydraulic motor. Check cables and wires that support the hydraulic electrical system. It's usual the little things that cause big problems
  • Posted 13 Mar 2009 22:45
  • Reply by Prentice
Thanks. Prentice.
The situation is intermittent. Is changing the whole contactor assembly going to fix this problem?
Would there be more work needed?
  • Posted 13 Mar 2009 04:46
  • Reply by hellokitty
Code 42 - Lift contactor closed when commanded open. Suspect you have a stuck pump contactor.
  • Posted 11 Mar 2009 22:29
  • Reply by Prentice
Lift Tek Elecar
Marko Tulokas Marko Tulokas
president and CEO, Konecranes
Director, solutions development procurement, Dematic
General manager - sales, FM Logistics India
CEO, Caterpillar Inc
June 3-4, 2025 - Sacramento, CA, United States
St. Louis, MO, United States
Flower Mound, United States
Newnan, United States
