Raymond easi opc 30 tt
Ser;easi-95-ab11633
No fault code when turning the steering over orange bar brake are apply.steer encoder test ok and proximity switch.any ideas
  • Posted 31 Jul 2009 03:41
  • By yan_l
  • joined 18 Dec'08 - 10 messages
  • Quebec, Canada
lamex.lift@yahoo.ca
If you hear the clunk then you have a steer/brake issue, not a mechanical binding issue. When you state that the electrical components tested OK is this through the lift or with seperate test equipment?
Have you relearned the speed as well?
  • Posted 31 Jul 2009 22:36
  • Modified 31 Jul 2009 22:38 by poster
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
Raymond alos updated this steer gear box to a "straight" style gear reduction as opposed to the offset style.They had issues with the retaining bolt shearing and the base plate on the gear box cracking.
  • Posted 31 Jul 2009 20:49
  • By chublil
  • joined 28 Jul'09 - 187 messages
Fix it right!!!
If its a steering isuue sometimes the pinion binds on the steer assy. and only with the tire on the floor, and you will get a steer prox or steer encoder fault when both test good.
  • Posted 31 Jul 2009 20:46
  • By chublil
Fix it right!!!
Normally the brake wires break or twist in the harness just above the motor, or right where they enter the brake head.
  • Posted 31 Jul 2009 20:44
  • By chublil
Fix it right!!!
same thing whit truck jacked.i did relearned, wire ok i hear the brake `clunk` whit the brake apply i still have throtle responce.
  • Posted 31 Jul 2009 06:13
  • By yan_l
  • Quebec, Canada
lamex.lift@yahoo.ca
With the truck jacked up does this happen?
Is the steering relearned?
Are the brake wires worn away or shorted together?
Do you hear the brake 'clunk' on or doe sit just not move?
Just a few places to look and start
  • Posted 31 Jul 2009 04:51
  • Modified 31 Jul 2009 04:53 by poster
  • By JonG
  • United States
