RAYMOND EASI DR30TT
Seri: EZ-B-00-17750 Lift, traction is ok but tilt can not.I check tilt motor 36VDC Damage but i don't know capacity of this motor.How many watts?Who's can help me
  • Posted 17 Aug 2013 01:55
  • By pham_s
  • joined 15 Dec'12 - 81 messages
  • 12, Viet Nam
phamquocsy9@gmail.com
Stam,because if's the first time i repair this model so i don't have much information, i forgot the switch LS at the PEDAL is damage, can not stop.can i change the same swich ( not RAYMOND),Do you have shop manual of this model?
  • Posted 18 Aug 2013 10:17
  • By pham_s
  • 12, Viet Nam
is the reach working is power steering working? if so the aux motor and pump is ok. as i said before i believe you have bad wiring. there is a small cable (#18/4) that runs through the reach assebly and provides power/ground for the solenoids behind the load backrest, these solenoids are for tilt/sideshift. the cable is bent up/down constantly as you reach and retract the forks causing it to wear and break frequently. check this cable!
  • Posted 17 Aug 2013 21:22
  • By stam
Stam, aux motor is damage, carbon brush...very bad.Run,Power steering, lift is ok but can not tilt, sideshift.the power supply to Aux motor when i push the button is 37.8 volt
  • Posted 17 Aug 2013 09:16
  • By pham_s
  • 12, Viet Nam
the tilt motor is called the aux motor, it runs power steering/tilt/sideshift. so if you have power steering the motor and pump is ok. check the wiring going from the carraige to the solenoids behind the load backrest.
  • Posted 17 Aug 2013 07:17
  • By stam
edition #1242 - 7 August 2025
In this week’s Forkliftaction News , we take a closer look at the main theme coming out of the recent CeMAT Australia event in Sydney: automation; why some are holding back and why not everyone will automate... Continue reading
David Wells David Wells
Chief executive, Logistics UK
National business development manager, Roadpod
Senior vice president, PEAC Solutions
Board director, UKMHA
Atlanta Savannah Orlando Tampa Jacksonville West Palm, United States
Sioux Falls, SD, United States
