Raymond 7400:
Raymond 7400 Service code X4
Trying to found out what code X4 refers to.
  • Posted 19 Sep 2015 06:30
  • Discussion started by Anyequip
If unit is passing all the test check and clean the VCM electrical connections. Seen this code happen with extremely dirty units. also check the wireharness for the lower switch t make sure its not damaged.
  • Posted 27 Feb 2018 04:50
  • Modified 11 Oct 2018 04:52 by poster
  • Reply by tyler_d
hehe!
  • Posted 1 Jan 2018 06:47
  • Reply by What2do
  • Tx
Debris on the lower caused the issue. Nothing to do with the wheel
  • Posted 8 Oct 2015 16:12
  • Reply by Anyequip
again which prox sensor you have its magnetic top prox sensor or the wheel encoder top 2nd mass and make sure your bottom prox sensor
is perfectly adjusted to the right height for first stage then when it reaches secondary mass away from free lift on the screen it will start marking height calibratio if its correct if not you might need to correct loosen and look at the display when correcting distance
  • Posted 8 Oct 2015 13:05
  • Reply by edwin_q
Eddie Rod #1
Found out the code was for switch mismatch. Both proximity switches in the mast were activated at the same time. Found debris blocking the bottom switch
  • Posted 3 Oct 2015 00:50
  • Reply by Anyequip
Are you sure on that code? What is the truck doing? is it driving ok besides that?
  • Posted 2 Oct 2015 21:19
  • Reply by EasiTek
Taylor TT300
USD98,500
Toyota 8FGCU30
Flesherton, Ontario, Canada
Louisville, KY, United States
Dubuque, IA, United States
edition #1228 - 1 May 2025
Hawker Powersource, Inc.
