Quits traeling at times.
I have a Hyster B60XT serial number B199H05995W, that will just stop traveling at times. The contactor never kicks out when it happens, and it will continue to kick in and out whenever travel is requested. I have replaced the contactor, and handle harness(it was damaged in two places). I have swapped the handle controls, battery and controller with a known good unit. The motor tested good so I have not swapped that out, yet.
Once the unit stops, it takes awhile to get it to move again, unless you use the belly button, then it will move. Any ideas are greatly appreciated.
  • Posted 7 Dec 2018 01:53
  • By lvscr
  • joined 24 Apr'14 - 41 messages
  • Idaho, United States
look at the battery's voltage under load
is there any error codes showing on the bdi
there is a couple of possibility's traction card in handle, drive motor phases,or tiler handle sensor is failing maybe broken wire
  • Posted 10 Dec 2018 00:03
  • By redbull
  • joined 14 Oct'16 - 108 messages
  • Queensland, Australia
