Question on EV100 handset
Does anyone know if an EV100 machine that does have a read out code in the dash, is able to read codes of an identical truck that goes down? If a cable is made from the card of the broken truck (w/out read out), to the connector of the operating machine (w/ read out), can the codes be read?
  • Posted 25 Jan 2012 22:03
  • By 7777
Would only be able to read the current code if this set up would work,with a handset can read the fault history for the ZX and SX cards(last 16 fault codes,with battery state of charge and hr meter @ time of fault. Plus as ED T has stated you can set up and adjust with the handset.
  • Posted 27 Jan 2012 11:50
  • By kevin_t
I really should have been a bit more accurate, and said that as long as it is an ev100 LX controller or newer it will work, one from a zx truck works fine on an lx truck.
The cable that plugs into the ev100 "y" plug is the same.
and
Note that Mack's information is good as far as ev100 traction controllers, but some other GE controllers may have the stored fault codes in a different setting.
and
Off the top of my head, I seem to remember that the cost of one of those ev100 dash gages is almost as high as the handset itself, and you will still need a handset to be able to setup a new or recon card to match the truck.
  • Posted 26 Jan 2012 21:05
  • Modified 26 Jan 2012 21:11 by poster
If you have an ev100 handset. function 1 is where the last logged code is stored.
  • Posted 26 Jan 2012 15:49
  • By Mack
  • joined 25 Feb'10 - 2 messages
  • British Columbia, Canada
Thank you ED
  • Posted 25 Jan 2012 22:37
  • By 7777
as long as the trucks really are the same controller
  • Posted 25 Jan 2012 22:22
