Quality of LP gas
With the new emissions standards has anyone noticed that the quality of the LP gas must be a lot better then it had been in the past in order to for trucks to perform. Seems to me that either the quality of LPgas has changed or the new emmission standards are effecting the performance of lift trucks.
  • Posted 11 Nov 2010 03:24
  • By Stacker
  • joined 11 Nov'10 - 3 messages
Showing items 1 - 17 of 17 results.
We did some testing and tjoldman is correct to install the thermostat before the vaporizer. We dropped the temp of the vaporizer or regulator over 20 degrees by doing so. The lower we keep the temp the lower we keep the tar content.
If you are like us if you check the number of filters you sell you will find the tech's are not changing the fuel lock filter, cleaning the last chance screen or draining the vaporizer.
According to Hendrix,Allied and several other fuel companies we checked with, anything over 140 degrees has a tendency to break the fuel back down into a liquid form.
Good luck guys
  • Posted 29 Jan 2011 00:20
  • By HuskerHound
  • joined 29 Jan'11 - 1 message
tjoldman, says; "install inline thermostats in the coolant lines going to the regulators" but this is incorrect and a type of "shorthand" that causes confusion and problems, since it is far more correct to say "install inline thermostats in the coolant lines leaving the regulators and going back to the engine" if you install it before the regulator, it will not correctly read the water temp in the regulator.
  • Posted 28 Jan 2011 21:31
Newer electronic injection systems are much better in fuel management but, the temperature of the vaporizor regulator is still an extremely important factor when considering the gunk that clogs up systems. Vaporizor Regulators need to be between 160 to 170 degrees to operate properly and not further "crack down" liquified propane. If you run higher temperatures, most systems will require more maintenance in draining the gunk and more fuel system component rebuilds.
In the old days we use to install inline thermostats in the coolant lines going to the regulators. These thermostats were normally wide open. When the temperature increased above 170 degrees the thermostat shut down and the vaporizor regulator cooled. The normal impurities and by-products (DURING the expansion and temperature change in the vaporizor regulators) of the liquid fuel better stayed suspended in the vapor and was burned in combustion and not deposited in your fuel system. If your engine runs hotter or a customers application causes higher temperatures, you will get more gunk (drop out from further cracking down LP) in the fuel system. Bad LP can also contribute to the problem no doubt!
  • Posted 28 Jan 2011 06:05
  • By tjoldman
  • joined 28 Jan'11 - 14 messages
A few years ago, when the Nissan K21/K25 FI engines were coming onto the market,(and suffering from a lot of fuel quality problems), I had lengthily conversation with a factory engineer, who claimed that the refineries were adding some of the sulfur based compounds that were no longer allowed in the new formulation Diesel fuels into the LP gas. Or more succinctly, the sludge that they were extracting from the Diesel was being dumped in the LPG. I don't know if any of that was actually true, but knowing what I know about oil refining industry, it wouldn't surprise me at all if it is.
It also seems to me that in the past year or so there have been a lot fewer fuel system failures directly related to fuel quality problems in my region, so perhaps the LPG industry is working to solve the problem.
  • Posted 26 Jan 2011 13:47
  • By fixitandy
  • joined 23 Mar'09 - 81 messages
Steponmebboom, you drain it after the reg has come to operating temp. Start the truck let it idle for about 10 minutes, shut it down and drain whats there. The sulfer additive must be hot to flow.
  • Posted 13 Jan 2011 21:31
  • By chublil
  • joined 28 Jul'09 - 187 messages
Fix it right!!!
I ask my customers what kind of L.P. they are buying and they have no idea. I even asked the guy filling the propane tanks what grade of L.P. he was filling and he had no idea. I know our CAT manuals call for HD5 but seems like no one knows what is actually going thru the forklift. No wonder I prefer to work on electrics.
  • Posted 25 Dec 2010 06:54
  • By BenH
  • joined 17 Aug'09 - 27 messages
Hang on a minute guys how often are you servicing your vaporizers and regulators strictly speaking most manufactures recommend ever 1000 hrs or once a year if light duty so just about every six months per truck now after saying that if we service them correctly gas problems should not happen regardless of how good or bad the gas is. Is`nt that why they have built in filters in the units?
  • Posted 4 Dec 2010 06:09
  • By daryl_j
  • joined 12 Sep'09 - 46 messages
  • manchester, United Kingdom
Can someone tell me the proper procedure for draining a vaporizer because in my 13 years as a tech I have never once removed the drian plug or opened the draincock on one single vaporizer and had even a trace of anything come out of it.
  • Posted 15 Nov 2010 09:09
  • By steponmebbbboom
I also did some testing at one account with an additive called CGX-4. It won't let me post the URL here but you can just Google it. There were some definite measurable improvements with it. The problem was getting the end-user to pay for it and make sure it got added to either their bulk tank or the truck cylinders on a regular basis. In the end, it was just too difficult to pull off. People have a mind set of doing something a certain way for years and they don't always like anything changing that.
  • Posted 12 Nov 2010 02:44
  • Modified 12 Nov 2010 02:45 by poster
  • By WMC1
  • joined 29 Oct'09 - 7 messages
We see a lot of problems here in CA with dirty vaporizers, clogged injectors, etc. One problem is that techs neglect draining the vaporizers on PM's. Still, fuel quality is a big problem. All of the local LP suppliers will initially tell you that their product is the best. When you question them a little though, it becomes clear tat they have no clue. Most are just selling the cheapest stuff they can get. It might work fine for a barbeque but not in a lift truck fuel system. I saw a statement from one person at the state level saying that there were regulations in place so there should be no problems. Problem is nobody is following the regulations and nobody is enforcing them. I am also not a fan of more government intervention but some sort of standards enforcement might be helpful in this case.
  • Posted 12 Nov 2010 02:35
  • By WMC1
We've seen higher tar content, both due to fuel quality and higher engine temps. Within the last 2 years we have also seen higher sulfur content. Sulfur content is required by CARB to be 80ppm or lower and we have seen test results as high as 213ppm. But of course the supplier claimed his fuel was pure. I am not a fan of bigger government, but the only way to cure this is that the LPG Industry needs to be regulated just like the gasoline industry was many many years ago.
  • Posted 11 Nov 2010 22:04
  • By Jeff
  • joined 8 Feb'07 - 61 messages
There is nothing worse than a sharp image of a fuzzy concept.
-Ansel Adams
Stacker, there is no doubt that engine coolant (and as a result, the LPG regulator) temp makes a lot of differneces in how much "goop" cracks out of LPG fuel. there is also a pressure problem that can be introduced when a gravity feed tank fill process is used outside in low temps, and then the filled LPG tank brought into a warm building and allowed to reach "room temp".
there is no government body that checks to be sure the LPG that is claimed to be hd-5 really is, as far as I know.
  • Posted 11 Nov 2010 21:21
joe d - Did you or anyone get a copy of those reports or even see one to compare ? If the say they have reports to prove it - start thinking like you are from Missouri & do that "Sho' Me Thing".
Have you ever heard a sales person say they sell crap?
  • Posted 11 Nov 2010 13:31
  • By johnr_j
"Have An Exceptional Day!"
We actually had the LP tested at the well head and it is withing guide lines. Does anyone notice if the tempature makes a difference
  • Posted 11 Nov 2010 07:42
  • By Stacker
Yeah, did that, John. They all said they had the best stuff and said they could prove it through their filtration records.
  • Posted 11 Nov 2010 06:05
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
Low grade LPG fuel contains excessive tars (honey as you say) and mess-up things. Many of the Japanese lift trucks had a device up thru the 1990's called a tar trap. The purpose was to collect the tar in the line between the tank & primary regulator. This trap had a drain plug on the bottom so the tar residue could be periodically drained.
You may want to talk to various LPG suppliers in you area about this issue to see who has the "good stuff" & who don't. Another suggestion is do a Google search on how you can determine what is good or not.
  • Posted 11 Nov 2010 05:03
  • Modified 11 Nov 2010 05:04 by poster
  • By johnr_j
I agree. I've had some serious problems with my tier 3s. I know on the old empcos, when doing the PM, you could remove a plug at the bottom of the regulator to drain some of the honey out but there isn't one on the woodward (there is one that could be used for that but due to the regulator being mounted upside down it ends up on top...they call it a pressure port on Clarks). I wonder if there's a filtration system that can be installed in line?
  • Posted 11 Nov 2010 03:53
  • By joe_d
Sue Tomic Sue Tomic
