Pros and Cons of the best TIRE usage
When operation requires combustion forklifts... please share your experience according to the usage of neumatic vs. solid tires.
Specifically on Radial Neumatics I got information regarding a longer life of the parts of the equipment, less damages or loss of tires due to heat problems and better occupational health for drivers.
Any pro´s and con´s according to your experience and the specific cargo you manage or activitiy?
  • Posted 14 Sep 2005 02:22
  • Discussion started by juanfe
  • CUNDINAMARCA, Colombia
It's difficult to discuss one type tire without comparing it to other types available.
Air tires give a softer ride, a larger "foot print" for better traction and floation. Air tires are also easier damaged and subject to punctures & flats. A variation to the air tire is "foam filled". It has a little firmer ride a little less "foot print" as compared to a true air tire. It is also somewhat of a skill to get just the right amount of foam in the tire. Too little and the side walls flex too much and heat and and are subject to side wall damage. Capacity problems can result from tires with too much give as well. Too much foam and the tire rides too firm and wears out the center of the tread.
Solid pneumatic tires have a smaller "foot print" and generally have less traction in gravel or soft surfaces. They also ride the firmest which can lead to product damage as well as being somewhat hard on the equipment. However, they are much more difficult to damage. From my point of view Tire life should be secondary. There is not a "best" type tire without considering the application. There are pros and cons to each type tire. I have not attempted to discuss tire cost as tires should be chosen for the application and not just because they may be cheap.
It all depends on which traits best serve the needs of your application as to which tire you should choose.
  • Posted 29 Sep 2005 21:59
  • Reply by tom_w
  • Virginia, United States
I would agree in most part to life of machine parts, but solid tyres do have their own attributes (depending on the work environment). depending on how often the truck is used will also have a bearing on the type of tyre, as solids have a longer life span.
  • Posted 28 Sep 2005 23:45
  • Reply by charlie
Johnston, IA, United States
Jefferson, WI, United States
St. Louis, MO, United States
UN Forklift FB25N1QZ1
JLG 1932R
JLG 1932R 2017
Flesherton, Ontario, Canada
