Propane regulator icing up and motor stops
I have a GCX50 clark propane powered forklift that will not rev up when gas pedal is pushed fast, only when pushed slow. The motor is a Perkins 4 cyl. It misses and blows black smoke when you try to go past a idle. The regulator and piping to the carb ice up and shut off motor. Is this a problem with the regulator?
  • Posted 18 Dec 2013 00:31
  • By tdarr
  • joined 3 Dec'11 - 44 messages
This condition usually points to a lack of coolant flow through the regulator/vaporizer.
Might be something as simple as low coolant level in the cooling system, or something more difficult to determine like a clogged coolant hose or piping.
  • Posted 18 Dec 2013 01:37
  • By L1ftmech
  • Tennessee, United States
yes it probably is a bad regulator, but check a couple of things first
- coolant level in radiator and reservoir
- while running if coolant is present in radiator check for circulation
in most cases when regulator starts freezing up it is either because of low coolant in the cooling system or a clogged up regulator.
you have 2 choices if the regulator is bad
you can try and rebuild it or...
just replace it with a new one
your choice
Note: in some rare cases the circulation can be restricted in the fittings and lines in the cooling bypass circuit so if you cannot find any other problems in the obvious areas then its time to start pulling hoses and fittings and checking thoroughly.
good luck
Toyota 3FD100
Maxlion FDR45
