Propane regulator icing up and motor stops
I have a GCX50 clark propane powered forklift that will not rev up when gas pedal is pushed fast, only when pushed slow. The motor is a Perkins 4 cyl. It misses and blows black smoke when you try to go past a idle. The regulator and piping to the carb ice up and shut off motor. Is this a problem with the regulator?
  • Posted 18 Dec 2013 00:31
  • By tdarr
  • joined 3 Dec'11 - 44 messages
This condition usually points to a lack of coolant flow through the regulator/vaporizer.
Might be something as simple as low coolant level in the cooling system, or something more difficult to determine like a clogged coolant hose or piping.
  • Posted 18 Dec 2013 01:37
  • By L1ftmech
  • Tennessee, United States
yes it probably is a bad regulator, but check a couple of things first
- coolant level in radiator and reservoir
- while running if coolant is present in radiator check for circulation
in most cases when regulator starts freezing up it is either because of low coolant in the cooling system or a clogged up regulator.
you have 2 choices if the regulator is bad
you can try and rebuild it or...
just replace it with a new one
your choice
Note: in some rare cases the circulation can be restricted in the fittings and lines in the cooling bypass circuit so if you cannot find any other problems in the obvious areas then its time to start pulling hoses and fittings and checking thoroughly.
good luck
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
Still GX10
Still GX10 2000
Poland
EUR950
UN Forklift FGL18T
REPOWERTEK Inc
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
