Princeton PB50 wiring diagram
I am looking for a wiring diagram for a Princeton PB50 forklift, I have a battery drain problem I am trying to resolve and I can't seem to find a wiring diagram. Any assistance you can render would be greatly appreciated, thanks.
Sam
  • Posted 23 Jan 2018 04:26
  • By sam78
  • joined 25 Sep'16 - 7 messages
battery drain?
try disconnecting the alternator and see if the drain goes away.
There are only a couple wires at the starter, yellow and white, Yellow is wire from circuit breaker panel and white wire is from battery.
Then you would have the main battery cable and possibly a ground cable.
If you have a drain pulling the battery down then check and see if the alternator circuit may have a hung regulator or something else in the electrical system , best way to check is to run a battery drain test using a vom meter or test light. When running a battery drain test always make sure the battery is fully charged and in good condition.
  • Posted 8 Dec 2018 00:29
Has anyone one helped, I need to figure out starter wiring on a PB-5o.
Thanks
  • Posted 7 Dec 2018 23:03
  • By mers
  • joined 7 Dec'18 - 1 message
  • Missouri, United States
Taylor THC500L
Crown CG33P5
