Hyster S25A:
Power Steering doesn’t work
I just picked up a well worn S25 and it works pretty well, but has no power steering. All other hydraulics work fine so I'm leaning toward a check valve or similar. I picked up a diagram manual off of eBay, but it doesn't give a lot of detail. Any ideas?
  • Posted 25 Mar 2025 10:36
  • Discussion started by Aliquantus
  • Minnesota, United States
Aliquantus,
There is a flow control valve that is supposed to ensure the steering has a constant flow of hydraulic oil. There could be a failed or sticking valve inside. Also, the hydraulic pump has the relief valve inside for the steer system. Connect a gage at the pump and turn the steering wheel until it stops. If you have no pressure, there may be a problem in cylinder, steer control unit or hoses. Will the steering work any if you run the tilt valve while trying to steer? Good Luck.
  • Posted 26 Mar 2025 05:55
  • Reply by Fishmech
  • Virginia, United States
Your Focus
edition #1234 - 12 June 2025
JLG 450AJ
JLG 450AJ 2017
Flesherton, Ontario, Canada
Taylor T520S
Your Focus
