Hyster UNKNOWN:
Power Steering and Lifting issues
So sorry for not knowing the model but it's really old but my issue is a couple weeks ago my hydraulic line busted and lost all my fluid. Well I have replaced my line and filled it back up with fluid and now my power steering and lifting capabilities work for a while then they stop for a while and it's just a back forth thing so what could be my issue?
  • Posted 26 Jun 2019 09:54
  • Discussion started by Panchito
  • Arkansas, United States
these old units have a 'priority valve' in the system that diverts some of the hydraulic fluid to the steering, usually when the steering acts up and it affects the hydraulic functions at the same time this valve is generally sticking and should be cleaned out (or changed if damaged).
Need to know the model and serial number of the machine to be certain where the valve is located. Most of the older trucks it was located underneath the floor plate, but at a point the newer models moved that into the hydraulic control valve. The very old trucks the steering was solely controlled independently from the hydraulic system by the orbital steering valve but from your description this doesn't sound like your truck is that old.
  • Posted 28 Aug 2022 00:55
  • Reply by swoop223
In general, I'd suggest making sure you used the right fluid and then make sure to work the system to get any air out of the hydraulic lines. Without any more information, that's all I can think of. Best of luck.
  • Posted 27 Aug 2022 04:49
  • Reply by Adam_Thrasher
  • Oregon, United States
A. Thrasher
UN Forklift FD50T-NJB3
UN Forklift FD35T
Hangcha CBD15
China
USD1,600
Taylor THC500L
Your Focus
