Popping noise when hydraulics under load
Hello, I have an intermittent popping noise when turning, side shifting and lifting. At the direction of mechanic I changed the pump but still have the noise. It seems to be coming from the pump area. It sounds almost like a gear skipping cogs but I can't find a schematic of what drives the pump from the engine. I am also wondering if it could be cavitation in the pump. Fluid is full and looks clean. I am wondering if it could be the filter is clogged but I'm not sure where the filter is located. Thank you for any help!
Mike
  • Posted 29 Nov 2020 18:25
  • By Mike_Shull
  • joined 29 Nov'20 - 1 message
  • Missouri, United States
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
REPOWERTEK Inc
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
Philadephia, PA, United States
Chandler, United States
