PM Freq. and cost
How often should these lifts be serviced with the six cylinder cummins? And how much does it typically cost? Is there more than one PM level?
  • Posted 1 Mar 2012 05:29
  • By ChrisD
  • joined 1 Mar'12 - 21 messages
  • Kentucky, United States
well chris
every mfg has thier own maintenance checks and methods they use
such as like cat
thier maintenance for thier model DP150 for instance
they have several intervals for different things to be done like
* Daily Prestart inspecton
*Every 50hrs or weekly
*Every 200hrs or monthly
*Every 1200hrs or 6months
*Every 2400hrs or yearly
and each one of those covers specific items to check or service. The daily one is just normal things such as fluid levels and visual inspections etc, as the schedule increases to longer hour intervals the list gets alot more extensive on what to service or check.
If you check across all the mfg's you'll see the same pattern as above but some differences. But generally a normal oil and filter change ,chassis lube and operation check happens about on the 200hr or monthly scale.
  • Posted 24 Apr 2012 09:21
  • Modified 24 Apr 2012 09:24 by poster
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Thanks! Is there two PM guides. For instance an A PM and B PM where certian filters are required to be changed? For instance Moffett does this with Diesel piggyback.
  • Posted 23 Apr 2012 22:26
  • By ChrisD
i'd check around on the parts pricing, i'm sure you can get a better deal than that
but the time frames mentioned between servicing is correct
I usually try and stick to the 250hr interval under normal use conditions. If its in a hostile environment (dusty yard) then you'll have to play it by ear and estimate the intervals depending on the condition of the oil and filters after changing them out the first time. It may require more frequent servicing under extreme conditions ;o)
  • Posted 22 Apr 2012 00:00
  • Modified 22 Apr 2012 00:03 by poster
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Hi, Cummins says to service motor every 250 hrs. and depending on how the machine is used and condition Taylor would be around 500 hrs. The cost for parts and oils depending on where you purchased them should be about $1000.00 for complete service.
  • Posted 21 Apr 2012 15:12
  • By bo_l
  • joined 21 Apr'12 - 1 message
  • Illinois, United States
Terberg RT223
Toyota 02-8FD25
edition #1286 - 18 June 2026
Leading the news in this week’s Forkliftaction News , Hyster launches a new electric counterbalance forklift which it describes as “a high-performance evolution of a proven workhorse”... Continue reading
