Plugging problem
Very stiff plugging when traveling power unit 1st direction and then plug. No problem when traveling forks first direction and then plug. The problem is not: Sevcon controller, dist. panel, F/W contactor, fwd/rev contactor or travel pot. Any suggestions besides an old priest, a young priest and some holy water???
  • Posted 23 Jul 2011 02:42
  • By jeffrey_r
  • joined 23 Jul'11 - 10 messages
Make sure your cables are connected correctly on the 1A contactor and the foward reverse contactor.. then green ground wire also should be on the the top lug of the 1A contactor.. if those are ok try a diffrent Sevcon.. good luck
  • Posted 4 Jan 2014 10:05
  • By irrk1
  • joined 5 May'11 - 24 messages
Check your key end keyway on your motor shaft. (both of them)
  • Posted 7 Dec 2011 04:07
  • By stucktruck
  • joined 27 Nov'11 - 17 messages
  • New Jersey, United States
there really should not be anyway that a power cable has anything to do with directional related changes, as the power goes through the same cables in both directions.
  • Posted 24 Jul 2011 22:19
Yes...even swapped drive motors just to make sure. I'm reasonably sure its a power cable issue. They of course check ok, but that doesn't mean anything under a load. I really hate to just throw parts at it like this but unfortunately that's where I'm at now.
  • Posted 24 Jul 2011 09:19
  • By jeffrey_r
are all the poles on the drive motors good and tight, and no shorts to frame after trying to drive then plug, in the power unit first direction?
  • Posted 23 Jul 2011 11:14
  • Modified 23 Jul 2011 21:26 by poster
Terberg RT223
UN Forklift FBR25NQC3
Sue Tomic Sue Tomic
Terberg RT223
Sue Tomic Sue Tomic
Hyster
Sue Tomic Sue Tomic
