pll atlet / nissan pll200
have a couple of trucks on site badged nissan but same as atlet pll 200 walk along usually after power on control arm screen asks for number both these trucks start straight up into drive mode do i need atlet zapi control to change back or is there a short plug somewhere ta anyone
  • Posted 14 Nov 2013 06:30
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
have sussed if you let the truck go onto standby then hold i button password screen appears and you are in, unless you have e056 (lift button fault) seems to stop atc from beeping supose you have to clear fault first will disconnect buttons next time to see ! but have substituted old head unit so not too hopefull
  • Posted 26 Nov 2013 07:13
  • By trevb
is there any way to fool the atc unit into reset to default, there is a battery on the atc card if i remove it will it default the settings thanks for your help
  • Posted 21 Nov 2013 07:49
  • By trevb
Hello trevb
Wat you need!!
Info about pll200
When you have display its the master of the truck you can't whitout display make change's on controller you need the display.
code 002468 service code
start code new 3333 old 2222
You need the tree for service let me now
I will help
John.
  • Posted 17 Nov 2013 01:24
  • By johngen
  • NB, Netherlands
ok i have found when replacing load wheels bumping of truck changes display back to enter code , searh in settings select key switch, no then truck starts as normal with log in code, switch it back to key ,yes and i cant use key pad again but how do iget back into controller to change it back, cant see option on menu tree for zapi cant get any info from atlet
  • Posted 16 Nov 2013 20:51
  • By trevb
Dallas, TX or Lexington, KY, United States
Highland, IL, United States
Orlando area, United States
Tacoma, WA, United States
Hyster
