Parts listing / Service Manual
Is there a reliable source for a parts listing and service manual for the FGF-040?
Serial number is E1828-216
  • Posted 21 Oct 2014 11:55
  • Modified 22 Oct 2014 01:46 by poster
  • By krygods
  • joined 21 Oct'14 - 1 message
Just came back to look around and realized I never answered your question. My build date is 4-11-57 and SN is 31211. I identified my engine as a Continental. I found an old air compressor with the same engine so I trashed the military distributor setup from mine and installed the regular type with new plug wires and solved my ignition problem. I found out the master cylinder is the same as an old Ford, wheel cylinders common so I got my brakes working. I'm still in search of a service manual if I ever come across one. It's a fun old lift.
  • Posted 2 Jul 2021 06:28
  • By jovan
  • joined 6 Jun'16 - 2 messages
  • Maryland, United States
Check us out at ATHS.org
You should be able to find a parts manual online. I've never seen a torque converter fail.
  • Posted 1 Jul 2021 21:19
  • By duodeluxe
  • United States
duodeluxe
No new information here, just more questions...
I too have an FJF 040
She is a '69, Continental #DSA-400-68-C-3692, S/N 55758
I have been able to locate a manual for a '71, but that is the closest I have come... I am looking for brake parts, and the torque converter gives up with very little resistance, so I'm guessing there may be some work to be done there. any direction or guidance is much appreciated- Thanks in advance!
  • Posted 22 Jun 2021 18:10
  • By AlaskaBaker
  • joined 22 Jun'21 - 1 message
  • Alaska, United States
Worth Fixin'
What is the serial #?
  • Posted 20 Oct 2018 23:05
  • By duodeluxe
  • United States
duodeluxe
I have a FGF-040 as well and I'd like to find out what engine it has. I can't find a tag on it anywhere visible. It is a flathead 4, likely a Continental or Hercules but I'd really like to know. I need a distributor and I don't know where to start. I'd also like to find a manual if one exists. It is a 1957 model.
  • Posted 6 Jun 2016 21:56
  • By jovan
Are you sure it is a FGF40? What size tires does it have and what engine?
There may be a printed manual available but there would not be an electronic version?
  • Posted 19 Feb 2015 10:51
  • By duodeluxe
  • United States
duodeluxe
For a truck this "young", there is most likely not going to be anything in electronic format, but most every piece is still available somewhere. the cost of upkeep for a truck of this age is far more likely to be the concern rather than availability. the truck's circuits are all pretty simple.
  • Posted 22 Oct 2014 21:02
  • Modified 22 Oct 2014 21:03 by poster
Lift Tek Elecar
