Os030EFN24TE095 (Fault Codes)
Anyone have experience with Yale order selector fault code 40099 and 30075. This truck lifts but, no travel.
  • Posted 24 Apr 2024 06:59
  • By Howard_N
  • joined 18 Mar'09 - 3 messages
30075
CALIBRATION REQUIRED
B.
STEER CONTROLLER WIRING FAULT
C.
CANBUS COMMUNICATION FAULT
NOTE
Please refer to the end of this procedure for supporting diagrams.
COMPONENT OPERATIONAL CHECK
NOTE: Always check battery condition and state of charge before performing electrical troubleshooting. A faulty or low charged battery will cause electrical features to not operate as designed and give incorrect readings while performing electrical tests.
PROCEDURE OR ACTION:
1.
Conduct a visual inspection of all connectors/wiring associated with the fault code.
Are any faults detected/observed?
YES: Repair/replace connector or wiring associated with faults found. Refer to the appropriate Electrical System YRM.
NO: Proceed to Step 2.
2.
Re-key the vehicle.
Is the code still present?
YES: Proceed to Step 3.
NO: Problem may be intermittent.
3.
Locate input diagnostics (D2.30) and verify steer status (D2.30.26).
Is the steer ON?
YES: Fault may be intermittent.
NO: Proceed to Step 4.
4.
Locate output diagnostics (D3.40) and verify status line operation (D3.40.6).
Is the status line ON?
YES: Suspect short to frame.
NO: Proceed to Cause A.
CAUSE A - CALIBRATION REQUIRED
1.
Calibrate the Auto Center STR (C3). For complete calibration procedures, refer to the User Interface Service Technician S/N A474N03000L=> S/N A497N030000L=> S/N D801N03000L=> S/N E826N03000L=> 2200YRM1651 manual.
Was Steer Wheel calibration successful?
YES: Clear status code and retest operation.
NO: Proceed to Cause B.
CAUSE B - STEER CONTROLLER WIRING FAULT
NOTE: Key in ON position
1.
Measure voltage between the steer controller B(+) terminal and B(-).
Is voltage 24 ± 2.5 Vdc / 36 ± 3.5 Vdc?
YES: Proceed to Cause C.
NO: Inspect power and ground cables for damage and loose connections.
CAUSE C - CANBUS COMMUNICATION FAULT
1.
Disconnect the steer controller connector A CPS120. Measure voltage between the steer connector CPS120, socket 14 and B(-).
Is CAN HI voltage approximately 2.5 Vdc?
YES: Proceed to Step 2.
NO: Inspect CAN HI circuit for open or short. If voltage is 0 volts, the CAN HI circuit is shorted to ground or open. If voltage is above 5 volts, the CAN HI circuit is shorted to power.
NOTE: Key in ON position.
2.
Measure voltage between the steer controller connector A CPS120, socket 6 and B(-).
Is CAN LO voltage approximately 2.5 Vdc?
YES: Disconnect battery and proceed to Step 3.
NO: Inspect CAN LO circuit for open or short. If voltage is 0 volts, the CAN LO circuit is shorted to ground or open. If voltage is above 5 volts, the CAN LO circuit is shorted to power.
3.
Measure resistance between the steer controller connector A CPS120, socket 6 and socket 14.
Is resistance 60 ± 6 ohms?
YES: No communication faults are present, connect battery and proceed to Cause B.
NO: If resistance is 120 ohms, the CANbus has an open circuit or a missing or damaged termination resistor. If resistance is 0 ohms, the CANbus circuits are shorted together.
  • Posted 25 Apr 2024 02:45
  • By David_Miller
  • joined 9 Feb'24 - 13 messages
  • Michigan, United States
Dave
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
Hangcha CBD15
China
USD1,600
Taylor TXB180S
