Omega Lift 2X serie 10,000lbs 2008-2009 - PROBLEMS
We purchased & operate several Omega Lift 2X series 10,000lbs vertical mast 2WD last year and we have run into several problem with frames carcking and we noticed cracks in the main frame rails just where the mounting block for the drive axle was welded to the frame. Also, the exterior beam of the lifting mast cracked on the top side of where the bracket for the tilt cylinder is welded to the mast.
We run several of theses units and cracks are appearing in all the same place on each machine suggesting structural design issues.
Is any one experiencing similar problems???
Has anyone else got any feedback about these machines or the Company representation that may confirm these are problems from the start????
  • Posted 21 Jul 2009 00:56
  • By dcarrier
  • joined 21 Jul'09 - 2 messages
  • Quebec, Canada
Unicarriers FD80-2
TCM FHD105Z
RAEDER-VOGEL
RAEDER-VOGEL
Unicarriers FD80-2
TCM FHD105Z
