nr 45 hyster
hello, I'm needing help with a forklift hyster NR45 (C264) that is introducing the fault code 52.
if you can help me thanks
  • Posted 26 Jan 2014 12:45
  • By gustavo_d
  • joined 28 May'13 - 6 messages
  • curitiba, Brazil
hello,
to help replace the motor direction to twenty days and during this period the equipment was ok and again to the same problem.
thank you
  • Posted 27 Jan 2014 10:15
  • Modified 27 Jan 2014 10:17 by poster
  • By gustavo_d
  • curitiba, Brazil
dallzzoto@yahoo.com.br
Please check your email
  • Posted 26 Jan 2014 22:45
  • By forklift_brazil
  • joined 15 Nov'12 - 108 messages
  • rio de janeiro, Brazil
tecmanuais@yahoo.com.br
skype:hyster.brasil
Display Message:
52 STR ENCODER FAULT
CALL SERVICE
Description:
The steer controller or caster controller has sensed a fault in the tiller encoder.
Symptom:
If moving, the speed command is set to zero, the electric brake is enabled, and the truck is disabled. If the fault is sensed at truck startup, vehicle systems will not be engaged.
Probable Causes and Test Procedures:
Verify 5 volts on pin #3 of the steering controller. If voltage is not present, check the steer controller for B+ voltage at the B+ terminal. Check the LED for solid light.
If voltage is good on pin #3, check voltage at pin #1 to the steer encoder unit, pin #B to th epressure transducer, and pin #1 (wire 250A) to the steer motor.
If any circuit is open, check the wiring harness for continuity. Inspect for loose or damaged pin connectors and for broken or damaged wires.
If voltage is less than 5 volts at any point, check for a grounded circuit by disconnecting the following components one at a time:
Steer Motor Connection
Pressure Transducer Connection
Steer Encoder Connection
Any voltage drop should be determined and the affected part replaced as necessary.
Check the continuity of all wiring from the steering encoder connections to the steering controller, steering pressure transducer and the steer motor.
Check voltage on wire #573, wire #574, wire #575, and wire #576.
Voltage on each wire should switch back and forth between 5 volts and 0 volts as the steering encoder is slowly rotated.
If voltage on all wires stays at 5 volts and 0 volts as the steering encoder is rotated, replace the steering encoder.
  • Posted 26 Jan 2014 22:41
skype:hyster.brasil
status code 52
Steer Encoder Fault (tiller)
may be a bad steer encoder on tiller or some connection problem
  • Posted 26 Jan 2014 13:20
  • Modified 26 Jan 2014 13:22 by poster
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Highland, IL, United States
Dallas, TX or Lexington, KY, United States
Tacoma, WA, United States
Orlando area, United States
