Nox sensor codes
So have a government truck here L006 and it is throwing a 3223-12 code. that is for Pre Nox sensor. all sensors have been changed out and the code keeps returning after an hour or so. i have 4 trucks all at the same location doing the same thing.
any help would be great
thanks
  • Posted 6 Jan 2024 07:15
  • By Nwrecchian
  • joined 18 Aug'22 - 19 messages
  • Maine, United States
Roy,
At the connector going to the HEGO, pin 1 is battery voltage with key on. No voltage, need to check fuse 10. Next, disconnect battery and check pins 2 and 5 resistance to battery negative cable, should reads less than 1 ohm. If resistance is high or out of range, need to check harness. Connect battery and check pins 3 to battery negative, then pin 4 to battery negative, both should read about 2.5 volts. If one is a little less or a little more that is OK. Both together need to be about 4.5 volts. Again, should they not read correctly, check harness. Last, check ohm reading between pins 3 and 4, looking for 60 ohms. All checks are made where the NOX sensor connects to the harness. Good Luck
  • Posted 12 Mar 2024 02:59
  • By Fishmech
  • Virginia, United States
I have same model doing that. Has been going on a year now. Have no idea, as soon as I turn it off it clears and can't trouble shoot what isn't there
  • Posted 8 Mar 2024 13:17
  • By Roy_Baumeister
  • joined 9 Aug'23 - 9 messages
  • British Columbia, Canada
I can see more specifically that code is for pre nox sensor heater error. Check battery > fuses > wiring. Good luck.
  • Posted 9 Jan 2024 00:46
  • By James_Brand
  • joined 13 Nov'23 - 6 messages
  • United Kingdom
Mitsubishi FD200
Terberg RT223
Tampa Florida, United States
Mitsubishi FD200
Terberg RT223
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
