Nothing working other than lights
Hi I've got a 2009 EFG 216 and everything has stopped working other than the lights and beacon, the battery is fully charged and 12 months old you can hear a click when you turn the key and occasionally the fan comes on but not every time.
All fuses are ok, the screen has voltage going to it but isn't turning on so looks like its needs replacing - would everything else stop working if the screen is dead? or is there likely a bigger issue?
  • Posted 1 Jan 2025 05:10
  • By Andrew_H134
  • joined 1 Jan'25 - 1 message
  • United Kingdom
Check voltages at multiple points to eliminate an dead/faulty contactor, key switch or emergency stop switch, dead screen should/could be measured over CAN line as the can should have 60/120ohm resistance.
2009 is a tricky year as that could be a machine with screen behind the steering wheel or the orange screen next to steering column.
Lights work because probbaly they run under separate module that gets power from first K1 contactor or in case of non jungheinrich install are directly wired to machine side battery supply connection point.
What I'm probably trying to state is that it still could be general voltage or self test fail issue.
  • Posted 5 Jan 2025 18:27
  • By Tanel_M
  • joined 18 Jun'22 - 90 messages
  • Estonia
ROYPOW
ROYPOW
