not activate the "rabbit".
I need help, I have an electric pallet yale-mpe-060 model with the A896 series. not activate the high speed, replace the controler iskra and not solve the problem. no code in the on-board display. check all parameters, and controller inputs. help please
  • Posted 5 Feb 2012 06:26
  • By tecforelec
  • joined 21 Dec'10 - 10 messages
  • P.R., Puerto Rico
I am having the same problem on a MPE060. W/Powed steering. No rabbit. Display shows signal to controller and I relearned steering gear sensor. Swapped out gear sensor and st.motor. ,no fault codes. Dont see and switch on rider platform.
  • Posted 11 Jan 2013 05:53
  • By ifsmike
  • joined 7 Jul'11 - 50 messages
when all else fails ,stand back and observe
Dose this truck have a tortise switch if so it may be stuck in.
also sensor on foot plate or safty arms if it is a stand on and ride truck may be open circuit check to see if they are working.
Titus
  • Posted 8 Feb 2012 04:53
  • By Titus
  • joined 6 Jul'10 - 185 messages
thanks logic , for your answer, I took the test and are arriving at the entrance of the box iskra, 24 volt direct rabbit come swith. if you have any other suggestions write me. thanks
  • Posted 5 Feb 2012 10:11
  • By tecforelec
  • P.R., Puerto Rico
do you need rabbit speed in both direction can't happen.No codes sounds like a safety sw not working right.Look at the handle wiring from the rail handle to the connector.
  • Posted 5 Feb 2012 08:24
  • By LOGIC
  • joined 6 Dec'08 - 70 messages
The simple things in Life are the greatest rewards!
Muncie, IN, United States
Toyota 02-2TD20
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
