No travel!
When attempting to go either fwd. or rev. the unit travels an inch or two and then stops and fault codes 66 or 68 appear.
Any ideas out there?
  • Posted 14 Sep 2023 07:49
  • By DaveSr
  • joined 2 Mar'12 - 53 messages
Never too old or too experienced to learn more.
Thanks again!
  • Posted 15 Sep 2023 04:29
  • By DaveSr
That could be the case. I would test the battery voltage at the positive terminal on each card first. One of the codes makes me think there may be a bad connection between the main controller and slave controller.
  • Posted 15 Sep 2023 04:11
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 226 messages
  • Wisconsin, United States
In your opinion if all the cables seem secure and the battery is amply charged, is there a possibility that one of the "traction controllers" is faulty?
  • Posted 15 Sep 2023 02:53
  • By DaveSr
Thanks!
  • Posted 14 Sep 2023 22:50
  • By DaveSr
Code -66: Field FET current exceeded expected current limit.
Code -68: PMT enable signal from slave controller (MRC2) to master controller (MRC1) dropped below 5 volts.
Just by looking at the codes, it seems there may be a short in the system. I would check motor cables for tightness and ensure battery voltages are correct on both the main and slave controllers.
  • Posted 14 Sep 2023 10:16
Lift Tek Elecar
Hangcha FLDCXT160
JCB 533-105
