NO Travel
Never worked on a Baker before. It has all hydraulic funtions and registers 36 volts on meter, low but should still work. Travel shows only 31 volts no matter where I check voltage. Anyone know what this could be? I don't have a book for it. Its a B-60-CE, 6K capacity, 36 volt.
  • Posted 21 Oct 2015 05:16
  • By zero
  • joined 21 Oct'15 - 1 message
Exact same issue here. no travel, hydraulics work. 48V battery Type: 24-120-17
Baker B-B60-CE
S/N: 2504-0105
Any help is appreciated!
  • Posted 11 Dec 2021 01:57
  • By Zimmark
  • joined 11 Dec'21 - 1 message
What's the matter with the unit just low voltage?
  • Posted 8 Jan 2016 03:46
  • By GeneBean
  • joined 13 Nov'15 - 18 messages
It sounds like the battery is has a bad cell(s) or needs replacement. How are you checking the voltage. The best way is with the key on, pull back on the tilt lever until it hits the stop and hold it for a few seconds until you get the lowest voltage reading. Use a volt meter and not the one on the truck because it isn't accurate enough. My guess is if it goes below 33 volts then the battery needs attention or replacement.
  • Posted 8 Jan 2016 00:11
  • By duodeluxe
  • United States
duodeluxe
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Taylor TT300
SMV (Konecranes) 20-1200B
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
