No Tilt unless lift locked up.
Customer complained lift gradually lost hydraulics/lift; No pressure detected at control valve port. Rebuilt pump as a precaution (no defects noted) and disassembled, cleaned and resealed spool valve and main/tilt relief valves. Now, after pressure set, lifts fine and pressure is in spec. No action or pressure detected when tilt only engaged. Only when lift is locked at the top does the tilt engage. Pulled tilt relief and inspected; not defects noticed. Also, polished the poppets between the spools (FYI, this is a two spool valve only.) Any help appreciated.
  • Posted 5 Dec 2020 02:11
  • By SWEnglert
  • joined 4 Dec'20 - 9 messages
Did you find a resolution to this problem. I'm having a similar issue with very slow tilt/ss functions unless you activate lift simultaneously then after auxiliary functions will work fast briefly.
  • Posted 15 Feb 2024 09:52
  • By Firemarshal
  • joined 11 Apr'20 - 3 messages
  • Oklahoma, United States
Mobicon 2T
Toyota 8FD45
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Mobicon 2T
Toyota 8FD45
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
