No start
4.3 vortec, lp. Tier 3? Maybe. Serial 70058
The truck is constantly flooding itself out and won't start. If you pull the fuel line off the mixer and crank it over you can get it to start and run and it will continue to run until you shut it off. It will start maybe 2 or 3 more times after that and then on the fourth start it won't start. Only crank because it is flooded again. I have replaced the EPR, the mixer, the electronic fuel lock off, I just went through this truck as well and has all new tune up parts, distributor, crank sensor. Pretty much replaced everything on the truck. I do have the laptop hooked up to it and can send pictures of the readings if needed. Any help will be appreciated as I'm stumped. Thanks
  • Posted 10 Aug 2022 12:12
  • By Bear
  • joined 10 Aug'22 - 1 message
  • Illinois, United States
Carb diaphragm.
  • Posted 16 Aug 2022 06:15
  • By grant_c
  • joined 12 Aug'16 - 27 messages
  • Manitoba, Canada
UN Forklift FBRS15KQZ2
UN Forklift FD15-18T
MAXAM Tire, Inc.
Muncie, IN, United States
Kai von Berg Kai von Berg
