Toyota 7FGU15:
No Start
I have a Toyota 7FGU15 that had a bad distributor. We replaced the distributor, but now have a no start condition. Found that the fuel lock-out solenoid is not energizing, no battery volts. Traced it to the relay. The coil to the relay is not getting a negative. The schematic appears to show it coming from the e/g rev switch.
Coukd this be a bad switch, or could it be related to the new distributor?
  • Posted 6 Aug 2015 07:15
  • Discussion started by d_g_j_h
  • Belgium, Ashmore and Cartier Islands
Wires from the distributor look ok. Could the e/g reverse switch be the issue?
  • Posted 8 Aug 2015 05:53
  • Reply by d_g_j_h
Hello, check the wires going to the distributor. they break up inside the harness. or along the top of the engine at the hold down clips.( Wears through). Very common problem.
  • Posted 6 Aug 2015 22:43
  • Reply by Prentice
Louisville, KY, United States
Dubuque, IA, United States
Enforcer FLBAXT25
Toyota 02-8FD25
