No Start
Hey guys, I have this old AC that won't start. Turns over but very slow even while being boosted. Checked cap and rotor,wires,plugs all ok. checked propane system seems ok.. It seems no matter where you position the for/rev pedal there is no difference Need some ideas. Thanks Rich
  • Posted 21 Nov 2008 08:37
  • By rich_k
  • joined 30 Oct'07 - 108 messages
do a voltage drop test on the starter cable
hook up 1 lead of the meter to the B+ terminal of the battery
hook up the other to the large cable terminal on the starter (the threaded post with alligator clips, not the cable terminal ring)
if the cable is good the voltage while cranking will be around 0v
if the cable is bad it will read voltage (even just 1 or 2 volts is bad and would indicate resistance in the cable where there should be none)
repeat this test for the negative cable (B- and the engine block or the metal housing of the starter)
  • Posted 22 Nov 2008 07:46
  • Modified 22 Nov 2008 07:52 by poster
  • By justinm
and the Ignition timing? and try a new battery, your old batery may be revesing polarity and still drawing down the boost, rather than the boost going to the starter...
  • Posted 21 Nov 2008 22:18
You say if turns over but very slow even while being boosted.
Have you checked out the starter???
  • Posted 21 Nov 2008 12:26
  • By tom_v
  • joined 18 Jul'08 - 7 messages
  • United States
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
Unicarriers FHGE35T5S
Hitachi HX64B2
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
