No start
This machine was worked on for a hub seal leak. The cab was tilted to replace the brakes booster assembly. There was also a jump wire install to put in a horn button. The power was pulled from a brake relay power wire. The machine has power at the dash, the shift lever activates the backup alarm; but when the key is turned to the start position there is no response it will not start. We tested and all other functions seem to be sending signal except for the start signal. We tested the ignition switch and we have a signal there for start. It seems like a bad relay or broken wire. We cannot locate the wire for ignition going through the harness. Any schematics or knowledge of the issue.
  • Posted 20 Feb 2018 07:19
  • By blake_j
  • joined 20 Feb'18 - 2 messages
  • Idaho, United States
Hello! I want to ask, did anyone used following resource of Caterpillar spare parts?
https://AFTERMARKET.EXPRESS/
This is the largest aftermarket base of spare parts I have seen, and it is also possible to select different locations by state. Very interesting resource!
Please share your experience, write your opinion.
  • Posted 23 Feb 2018 02:46
  • By George_Grey
  • joined 23 Feb'18 - 1 message
Sorry I had listed the machine info when I opened the question. It is a Cat mdl- P30000 sn- T38A-10026
  • Posted 20 Feb 2018 13:30
  • By blake_j
People might need the complete model AND serial number to help you.....
  • Posted 20 Feb 2018 12:35
  • By kevin_t
Tampa Florida, United States
UN Forklift FD50T-NJB3
Toyota 02-2TD20
Toyota 02-2TD20
ROYPOW
