No rpm on my Doosan G30P-3 Forklift please help
I'm getting codes 25-27-37-47 starts but no acceleration no RPM's code 25 Throttle Sensor range hi I checked it for corrosion and resitance code 37 IAT sensor input low checked TMAP for resitance code 27 predicted differance engine does not shutdown so that one is out code 47 I could not find any info for that one???? also how do you reset the computer codes please help me with anything you can suggest I try. thank you
Paxton Mitchell Co.
Omaha,Ne.
  • Posted 8 Apr 2010 03:54
  • By corey_u
  • joined 8 Apr'10 - 2 messages
Sounds like you have a bad throttle pot sensor. You can clear the codes by turning the key on and depressing the accel pedal 10 times in 5 seconds. ( Just like retrieving the codes - 3 times in 5 seconds)
  • Posted 3 May 2010 12:58
  • By roadtek
  • joined 4 Dec'07 - 123 messages
