NO POWER
Hercules 2.7 motor runs but has no power, spark plugs look good as do wires. New carb (propane) advancing or retarding timing has little or no change. Also seeking firing or can anyone help?
  • Posted 16 Nov 2006 06:01
  • By albert_h
  • joined 22 Aug'06 - 59 messages
Thanks for the help found out it was busted timing chain.
  • Posted 3 Jan 2007 01:35
  • By albert_h
For some reason or other those herc 2.7 disturtors give me trouble. I'd start with a complete tune-up and check your air gap in the dist. (can't recall gap spec)
Your carb should be a impco 100, check to be sure you mix is set right. Also check your regulator. If it's stuck open you'll be flooding raw propane into the engine. Take the hose from the convertor to the carb off, at the carb and turn the ign on. If you hear hissing, or propane sperts out, your converter is bad. It is designed so that propane is sucked out under vaccum, not forced out under pressure.
firing order 1324 or 1342 can't remember
good luck
  • Posted 29 Dec 2006 13:19
  • By Stickboy
  • joined 29 Dec'06 - 2 messages
  • Wisconsin, United States
