Hyster H2.5TX:
No power
There is no power when the switch is on or off, I checked the battery it is ok all fuses checked there were ok, as well.
  • Posted 30 Aug 2024 10:44
  • Discussion started by HOSSEIN_NOROOZY
  • Victoria, Australia
Hossein,
Faulty starter or starter relay. Make sure lift is in neutral. Lift needs to see park brake engaged. Make sure PB switch is working. Possible key switch has failed. Verify power going to solenoid at starter when switch is engaged. Loose cable connections or bad ground can cause this issue. Good Luck.
  • Posted 10 Sep 2024 22:51
  • Reply by Fishmech
  • Virginia, United States
Hangcha FLDCXT160
Taylor THC500L
St. Louis, MO, United States
Jefferson, WI, United States
Johnston, IA, United States
