Raymond EASI R40TT:
No power
I'm working on our Raymond R40TT and have developed a no power at all situation. After replacing the Mast cable it had a little to much loop and extend function crunched the cable and shorted out. It blew the fuse out on the board big time, put a new fuse in and no power anywhere. Pulled the boards and don't see any burnt areas just thought someone might have direction for the next thing to check.
Thanks
  • Posted 24 Aug 2016 13:39
  • Discussion started by SeeScooter
  • CO
it's rare for an ez-a to not do anything, typically its the display unplugged, can you check your connections on the system card? specifically the ones that have screws mounting the plug. the speed encoder can plug into the display port and vice versa, also there is a diagnostic port that these connectors will fit into and create this scenario.
if above is all good, ohm out fuse fu4 (on system card) to the keyswitch wire s2 (at the key), should have continuity. if the fuse was of a higher amperage the potential is there for the system card to have been damaged.
also check key switch wire s1 to terminal strip ts19-5 (mast cable terminal strip) should have continuity.
  • Posted 25 Aug 2016 20:25
  • Reply by stam
Thanks for the reply stam, I should have put that in my post. EZ-A-00-16236.
Need serial number to assist with this.
There are a few versions of this truck.
  • Posted 25 Aug 2016 09:37
  • Reply by stam
edition #1234 - 12 June 2025
Big Joe PDR30-154
USD7,500
Toyota 02-8FD25
